Ignition Coil Test (Single/Dual Ignition Systems)
Bear engine analyzer only!Ignition Coil Test:
- Perform ignition coil test only at idle rpm.
- In addition, the ignition coil must be checked against the oscilloscope pattern in the single display mode.
- Program selection "engine electrical ignition coil test."
- Test and Adjustment Data, Test and Adjustment Data [Specifications]
