Electronic Component Replacement
^ Before servicing electronic components, disconnect the battery ground.
NOTE: Before removing battery ground, access trouble codes. ECU memory will be erased if ground cable is removed.
^ Fuel and Engine Control System wiring should be at least 4 inches away from ignition wires.
