Fuse & Relay Box - Threaded Sleeve Replacement
TO: OUR MERCEDES-BENZ PASSENGER CAR DEALERSDATE: September 1991
REF.NO. 54/68
SUBJECT:
MODEL 124
REPLACING THREADED SLEEVES IN FUSE AND RELAY BOX
The threaded sleeves for the rear mounting screws of the relay box cover (arrows, Figure 1) can be replaced in cases where the screws have seized and need to be drilled out.
Procedure
1. Remove fuse box cover.
2. Unscrew mounting screws.
3. Drill out head of seized screw(s) with 7 mm dia. drill bit.
4. Remove relay box cover.
5. Carefully knock out threaded sleeve(s) with a drift punch.
6. Coat new threaded sleeve(s) with Loctite and draw into housing using a screw.
7. Reinstall cover.
Parts Information
In Case of Warranty
