Tandem Pump (TANP) Models 67 167
Tandem Pump (TANP) Models 67 167NOTE:
For application identification refer to "Steering : Power Steering Pump : Diagrams : Application and ID" Application and ID
TANP - Models 67,167:
Pump Housing (2)
Flow Control Valve (2c)
O-ring (2g)
Bearing Flange Housing (4)
Bearing Flange Cap (4a).
Screws MB (4b)
8 Screws M6 (4c)
Radial Seal Ring (4d)
Radial Seal Ring (4e)
Shaped Wedge (4g)
O-ring (4h)
Piston Support Ring (5)
O-ring (5a)
O-rings (5b).
Piston (5c)
Piston Springs (5d)
Bearing Sleeve (5f)
Bearing Shell (5g)
Spacer Washer (5h)
Cam Insert (6)
Straight Pins (6a)
Rotor (7)
Vanes (7a)
Pressure Plate (8)
O-ring (8a)
Shaped Wedge (8b)
Drive Shaft (11)
Locking Ring (11a)
Reservoir (35)
Vent Cap (35c)
End Cover (35d)
Self-locking Nut (35e)
Plastic Sleeve (35f)
Spring (35g)
Filter Set (35h)
O-ring (41)
