Shift Solenoid: Description and Operation
PURPOSEThe switchover valve (Y3/3) controls the vacuum to the control pressure cable element.
LOCATION
The switchover valve is located in engine compartment at driver side firewall.
OPERATION
The LH control module controls the switchover valve. When the valve is energized, manifold vacuum reaches the pressure cable vacuum element and delays the transmission upshift point.
