GF27.10-P-3015AHW Power Flow In 5th Gear, Function
GF27.10-P-3015AHW Power Flow in 5th Gear, Function
2 Turbine wheel
3 Stator
4 Impeller
5 Small ring gear
6 Dual planet carrier
7 Sun gear
8 Large ring gear
9 Ring gear
10 Planet carrier
11 Sun gear
12 Ring gear
13 Planet carrier
14 Sun gear
16 Torque converter lockup clutch
41 Multidisk brake BR
42 Multidisk brake B1
43 Multidisk brake B2
45 Multidisk brake B3
46 Multidisk clutch K1
47 Multidisk clutch K2
48 Multidisk clutch K3
49 Short planetary gears
50 Long planetary gears
51 Planetary gears
52 Planetary gears
A Input
B Output
Function requirements for power flow in 5th gear, general
^ Circuit 87 (connected circuit 15) ON
^ Engine running
Power flow in 5th gear, general
The following multidisk clutches are engaged:
- Multidisk clutch K1 (46)
- Multidisk clutch K2 (47)
- Multidisk clutch K3 (48)
In 5th gear, power flows from the transmission input shaft through the blocked Ravigneaux gear set and blocked front single planetary gear set to the transmission output shaft. This rotates at the transmission input speed in the direction of rotation of the engine.
