GF27.10-P-3031AHZ Power Flow In Reverse Gear, Transmission Mode C, Function
GF27.10-P-3031AHZ Power flow in reverse gear, transmission mode "C", function
- Model 164.1
- TRANSMISSION 722.902/903/904/906/907
- as of model year 09
- Model 164.8
- Model 251
- TRANSMISSION 722.902/904/906/999
Function requirements for power flow in reverse gear in transmission mode "C", general
^ Circuit 87 ON
^ Engine running
Power flow in reverse gear, transmission mode "C", general
The following multi-disk brakes and multi-disk clutches are engaged:
- Multidisk brake BR (41)
- Multidisk brake B3 (45)
- Multidisk clutch K3 (48)
In reverse gear with transmission mode "C", the power flows through the following gear sets:
^ Ravigneaux gear set
^ Rear single planetary gear set
^ Front single planetary gear set
Ravigneaux gear set
The small ring gear (5) is driven via the transmission input shaft. The long planetary gears (50) drive the short planetary gears (49) which roll in the stalled large ring gear (8). The increased torque and reduced rotational speed as a result are transmitted to the dual planet carrier (6).
The ring gear (9) rotates at the same speed due to the mechanical connection to the dual planet carrier (6). The planetary gears (51) roll on the sun gear (11). Through the stalled planet carrier (10) a reversal of direction of rotation occurs at the sun gear (11).
There is a connection between the sun gear (14) and sun gear (11) via the engaged multi-disk clutch K3 (48). As a result sun gear (14) rotates at the same speed and direction of rotation as sun gear (11) and drives the planetary gears (52). The increased torque and reduced rotational speed as a result are transmitted via the planet carrier (13) to the transmission output shaft. The transmission output shaft thus rotates at reduced transmission input speed opposite to the direction of the engine.
