GF27.60-P-3018G Shift Valve Pressure, Function
GF27.60-P-3018G Shift valve pressure, function
- TRANSMISSION 722.6
Operation
The shift valve pressure is derived from the regulating valve pressure, regulated at the shift valve pressure regulating valve and is then present at
^ 1-2 and 4-5 shift solenoid valve (Y3/6y3)
^ 3-4 shift solenoid valve (Y3/6y4)
^ 2 - -3 shift solenoid valve (Y3/6y5)
^ Torque converter lockup PWM solenoid valve (Y3/6y6)
^ 3-4 and 2-3 shift pressure shift valve.
The shift valve pressure controls the command valves via the upshift/downshift solenoid valves.
