GF27.60-P-3019AHW Torque Converter Lock-Up Clutch Control Pressure, Function
Function requirements for torque converter lockup clutch control pressure, general
^ Circuit 87 (connected circuit 15) ON
^ Circuit 61 (engine running)
Torque converter lockup clutch control pressure, general
The torque converter lockup clutch is operated at specified slip speeds. In order to make this possible, variable control pressure has to be applied to the torque converter lockup clutch regulating valve.
The torque converter lock-up clutch control pressure is adapted to the respective operating state via the torque converter lockup clutch control solenoid valve (Y3/8y8) which is actuated by the fully integrated transmission control unit (Y3/8n4).
