Axle Shaft Assembly: Service and Repair
AR35.31-P-0530-01B Secure twelve-point and hexagon collar nut on drive pinion joint flange
- Rear axle center assembly dia. 198 [models 211, 230]
Chisel for securing collar nut on joint flange
Do not subject to hard axial blows.
Component Identification:
1 Use a caulker to caulk the twelve-point collar nut or hexagon nut with collar (40) into one of the two grooves of the drive pinion gear so that there is no longer a gap between the groove and the locking tabs.
Shown on 198 mm dia. rear axle center assembly
