RA03001194350X Starter to Ring Gear Clearance Adjustment
Preparation
- Starter removed.
Procedure
- Adjust clearance of starter to ring gear with shims (7, 8).
NOTE:
- The specified positioning of the starter relative to ring gear is adjusted by shims (7, 8).
- The correct clearance ensures that the starter pinion engages and releases properly.
- When performing removal and installation work, pay attention to shims (7, 8) and adjust clearance of ring gear to starter, if necessary.
Starter To Ring Gear Clearance Specifications Table
Clearance of rear edge of crankcase to at starter front edge of ring gear: 14.3 to 15.2 mm
No. of shims fitted: 0
Clearance of rear edge of crankcase to at starter front edge of ring gear: 13.3 to 14.2 mm
No. of shims fitted: 1
Clearance of rear edge of crankcase to at starter front edge of ring gear: 12.3 to 13.2 mm
No. of shims fitted: 2
