AR26.60-P-0600A Remove/Install Center Shift - 717.4 Transmission
Removal and Installation of Center Shift
Removing, installing
1 Move transmission into neutral
2 Disengage, engage (1-2, 3-4, 5-R) at the intermediate shift levers
3 Remove cover on shift lever
4 Disconnect plug connection on reversing light switch (S16/2)
5 Unclip control cable of parking brake to the side
6 Loosen hexagon nuts and remove bearing bracket
7 Install in reverse sequence
8 Adjust center shift
