The other day, I felt a bit of a hesitation while accelerating from idle. Thought I'd need to check into it soon.
Today I changed the fuel sending unit o-rings... gas smell in trunk after fill up and also noticeable gas stain on tank around and under sending unit.
15 minute job...easy... and then drove to station to fill up with 93. On the way back car felt like it went into limp mode. Bogged down and stumbled on acceleration from low speed or idle. Drove a bit farther to try to find more symptoms. Manually shifted into 2nd with revs up seemed to run ok but still stumbled on acceleration.
Got home drove into garage and took the attached video.
Shut down car. It wouldn't restart... cranked fine and would almost fire up... 2 small backfires and then just cranking. Went out an hour later and it started but still very rough idle.
I've been reviewing all the posts here and seems like I should start with caps/rotors/insulators. I have found quite a few original parts on this car over my 18 months of ownership and am guessing those things haven't been addressed yet, so whether that solves my problem they probably still need changed.
My biggest issue is no climate control in garage and 90 degree ambient temps
View attachment SVH 500E rough idle.m4v
