93 500sl LH issues
Rico nelor
Greetings! And thanks for adding me to the group! I've followed the thread re: 500e LH module, capacitor replacement. Apparently the sl suffers the same gremlin! My car when cold, the fuel lines would thump, and the engine would misfire. I also noticed the relay clicking as well, and when engine idle increases, it stops. I pulled the green relay and the engine shut off. When relay circuit was jumped, terminals #30 and 27, the pumps ran. Terminal 86 I think, had 12volts ignition switch is turned to 2nd position. So i installed a fog lamp relay (30amps), and wired it into the relay sockets of the car. It runs beautifully!! I also ordered the 100 and 22uf capacitors, and will install them myself. Question tho...will the 92 LH module with wot, work on my car???
Cheers and welcome!
As Gerry mentioned, indeed it will work. I have 95 SL500, running WOT LH module from 1992 500SEL
32488533438_720a109708_c-jpg.118906
Regards,
D
Ditto what Gerry and Jlaa DuhVinci said above. :plusone:
What part number is your LH module that has failed capacitors?
My car being 93, doesn't have mot upgrade?? Or is it just for 91??
mot? If you mean wot, none of R129 had those optioned modules to my best knowledge . From what I recall, the early, CIS cars actually were rated at the higher hp than LH, but wot never given to R129, at least not in US market…
My car being 93, doesn't have mot WOT-erichment upgrade?? Or is it just for 91??
It depends - you need to check the part number on the module currently installed. If you didn't buy the car new in 1993, there's no way to tell if if a previous owner or mechanic replaced the module in the past.
