Alternator, charging and current draw
Seangbadee
I noticed recently that everytime my AC kicks in, I feel a power (current) draw, and the same thing occurs whenever I power my windows up or down.
I took some readings with only the engine running and the current voltage is in picture 1:
I put the lights, radio, AC, interior lights and the current voltage dropped as low as 13.98
I have a 143Amp alternator with my rebuilt voltage regulator in
Should I be concerned ?
13.98 is not low when the car has all accessories on IMO.
Looks to me like your alternator is doing a good job
It’s still concerning that I feel the temporary the power draw; it feels like an ever so slight power drop.
Ref the voltage regulator, you call it a rebuilt one.
Do you mean a new voltage regulator is installed? If so, what brand?
Any slight 0.X Voltage drop when a high draw accessory is turned on is somewhat normal.
Example, if I have the headlamps on at night and I am watching them closely plus trip the window up switch I can see a small milisecond dip in the headlamp power. This is just normal behaviour and nothing to be concerned about.
If however you switch the headlamps on for a number of seconds (5+) and the voltage dips below say 13.5V then there is a potential alternator issue
Those readings are EXCELLENT.
With stock 110A alternator you might see voltage (not current) drop below 13.0...
Flip on high beams, fog lights, max HVAC fan speed, and rear defrost to really load up the alternator. I bet the voltage stays 13.5 or higher, which is still excellent for that much load. The 143A upgrade makes a significant difference.
:shocking:
:shocking:
Okay, I will
