Hi all,
Cer washing season is coming again and it's got me thinking about adding a water filter system which is designed to allow rinsing of the car and no need to dry it after.
Aka any minerals in the tap water are removed so as no water staining/ spotting occurs.
Almost seems too good to be true- but if it works will save alot of time and chamois micro swirls etc in the paint.
That particular filter appears reasonably priced at about £55gbp.
You would connect this to your garden hose only for the last rinse along with a low pressure spray head. (Would be a waste of the filter if you plugged it into your pressure washer etc)
Have any members used such a system?
Does the paint dry clean and spot free?
Is it better to use an air blower also to remove the bulk of the rinse water after?
