Hello.
One of my auxiliary fans hasn't been working for 2-3 years now... It's seized. (going to be replaced in the coming week, finally)
My question is : would this failed fan cause the other auxiliary fan not to kick in when a/c is turned on???
The only way for me to have the working fan kicking in is to "jump start" it with my foot (making the fan rotate when spinning it with my foot... If that makes sense to you)
High speed fan seems to be fine... Never needed it as the engine temperature never goes high enough (but I tested it by unplugging the coolant temp sensor when engine is at normal temp)
