OWNER Bahnstormer
It's an Ed Pink (Singer) 3.8 with ITB's, coil on plug ignition, GT3 intake, Carillo rods, Singer Mahle, GT3rs crank and many more tasty bits & pieces....
Cool...... bringing it back to MB-land ..... How does the coil on plug work .... meaning .... does it retain factory Bosch Motronic, or does it use aftermarket engine management? The distributor / plug wires setup on the w124 M119 is such a weak point ....... would be great to figure out a way to go coil on plug without using aftermarket engine management.
It uses an AEM management system with a custom harness to each coil. The original intention was to use the stock 964 intake/ignition but with the light weight engine internals it just couldn't keep up... Not a cheap or easy swap to the coil on plug system but it works flawlessly.
I'm back. More importantly the 500e has now been recommissioned out of long term storage! It's a long story but in short, my original plans for the car became unnecessary; I loved it regardless, so rather than sell it I decided to properly moth ball / store it for another day. Around 12 years later, today was the day that I collected it from my Mechanic to drive it home.
About a month ago he picked it up with his enclosed race trailer (with winch) from the very fancy executive aircraft hangar at the local airport where it had resided. He went through the car, inspecting every mechanical component and then flushed / changed all fluids prior to starting it. So far all it has needed has been a new battery, tires, brake pads all round (as a precaution) and a can of refrigerant for the AC. I'm sure that there will be more to deal with once its got some more miles on it - but I'm so impressed that it needed so little after such a long hibernation....!
Its about an hour drive from my Mechanic's shop so I was able to reacquaint myself with the 500e experience - which is so unique. I did not remember just how 'compact' the 500e actually is but that is in no way a negative. You all know what I'm referring to when I say that the way these E500E's feel is unlike anything else - it was nice to feel that again.
So I'm going to add to the current 181K miles over the next few months and see how we get along (outside of the gorgeous looks category) - then time to decide what to do.
A BIG THANK YOU to @sheward for originally selling this car to me but also for being a true gentleman in helping me to resolve an issue that was completely of my own doing. This forum is a great place and he embodies all that is great about it. Thank you my friend.
Here are a few pics from today with the stablemates.
View attachment 192822View attachment 192823View attachment 192824View attachment 192825
Welcome back Kotter, I mean Bahnstormer! 12 years - whew! Are the tires even still round after 12 years? :duck:
I've been driving the 500e around for the past few days to reacquaint myself with the w124/e500e - just short trips but long enough to bring it up to proper operating temps. I know I'm preaching to the choir... but aren't these cars just amazing..?
To this point, the only 'issues' have been a loose banjo bolt on the fuel pump which resulted in a very small gas leak after the first long drive home; and the Becker 1432 threw the E2 code after a few minutes.
I tightened up the bolt & checked all others on the pump/filter and it seems to have sealed. I'll look into what I need to do to resolve the Becker E2 fault.
Not bad (so far)... Did I mention how great these cars are...???
I saved these error codes sometime ago. Check the receiver module in the trunk.
Thanks J. I did check it - everything was properly attached and the fuse was good. Looks like I'll be sending it off for refurbishment. However I am quite enjoying the near silence while driving....
Had my detailer over to address some minor paint swirls/scratches caused by the cover while being stored. 040 is spectacular when clean!
In my experience, ceramic coating can be hit or miss but I wanted to add a protective layer after the polishing/correcting. My detailer swears by the Graphene 'advanced' product so I took his advice. The initial results are impressive - apparently the results improve after 'curing' for a day or two.
Got a link to the "Graphene Advanced" product?
What's so hit-or-miss about ceramic coating?
Note - I've never ceramic coated my cars before. I just buff and wax them every few years.....
I think ceramic coatings are most successful on new cars following paint correction. In my experience with having older cars ceramic coated, every stage of process has to be done perfectly for the results to be amazing. I've had a couple of cars done in the past that were just OK - could have been the product but most likely the process wasn't as meticulous as it needed to be.
Graphene Ceramic Coating™ Advanced - assumption of which one he is talking about.
Correct - thats the stuff.
Today was a nice warm / sunny day here in MI so I treated my seats to a couple of coats of my favorite leather conditioner and let it soak in the heat of the sun.
I'm preaching to the choir here but aren't these interiors just wonderful...!? Amazing how well the materials hold up after 30 years and 182k miles.
