Today, I drove the 300D down to the Pull N Save in Tucson, Arizona
Weather here is great! A little cloudy, but it was about 70F the whole time. I came for a 1988 300CE and got a lot of goodies
One of the parts I wanted specifically... it's hard to put a name on it. And it's almost impossible to find the part number!
It's a brake line... isolator? damper? guide? I'm not sure of the name. But mine on the 300D are melted into pieces.
Basically, it's a rubber piece that is under the car (on the left side) that holds each of the brake lines. There's a portion in the middle with a circle hole where a stud from the body goes through. Then you can fit each brake line in snugly with the closed part on top. There's a form fitting metal cover "clamp" which goes under the rubber and keeping it all together, there's a plastic screw with a Phillips interface that you put into that middle part which has the stud. This pulls the guide snug against the body.
Here are mine. The first picture is the best shape one I had. The others were just falling to bits.
When I try to find the part number for this, I can't seem to find it. I'm going to keep looking - but maybe @gsxr has some tips. I was looking in group 42 (brakes) and then there's a sub group for brake lines. EPC doesn't show it (unless it's in another group).
Back to the junkyard. I got these parts from the 300CE and they're a bit different. Picture one shows the individual pieces and picture 2 shows it together. When it's on the car, it's upside down (screw down).
This is a bit different... The 300D had spaces for 3 lines and a thinner uneven clamp. The 300CE has spaces for 4 lines and an wider and evenly spaced clamp. This part is close enough - I replaced 3 of the 4 melted ones on the 300D.
As far as I can tell, this one from the 300CE is part number
At this point, I don't think it matters - these should do the trick. But I know many of us (myself included) are pedantic and like to find the exact part number
I am really curious if it's in stock!
The other parts I got were also good - but nothing too exciting. 2x front ABS sensors (left/right), 3 sets of left/right brake wiring clips (
129-476-03-84. I didn't find that in any parts system - I found that part on TheSLshop.com after a ton of searching.At this point, I don't think it matters - these should do the trick. But I know many of us (myself included) are pedantic and like to find the exact part number
124-546-14-43 and 124-546-15-43), a Becker BE780 radio in great shape, and a few other items - all for $28 after tax
