When i changed sparkplugs in my E420 i saw it was the "bad/resistor" Bosch FR8DC in it. All the partsstore in Sweden recomend these horribly wrong sparkplugs. I ordered a set of 8, fresh Bosch F8DC4.
This time however i ordered direkt from MB-germany and when i got them i saw it was the non resistor Champion C11YCC. I did some research to se wich of these two that suits the 500 better. The differens i saw was that the Champion had double copper core on its terminal type (just copper core on the Bosch). I also saw that copper is better material for heat conduct. So 1-0 to Champion then (?). I also saw that terminal type was M4 thread on the Bosch and fixed terminal on the Champion. Is there any differens here? Does it mean that you are able to unscrew the terminal on the Bosch and not on the Champion?
So far i have concluded that the Champion (on paper) will resist heat slightly more. My second thought is: Wich one is the best? Is it like the distributor caps? When you order them original you will not get Bosch wich is the better one? Should i run Bosch or Champions? Why do not Mercedes recommend the best possible brand (like the case of the distributor) ?
