Sorry to keep bugging you guys with my fight and this car but don't know where to get info on these issues from folks I can really trust other than here. Car runs very well now but the AC is dead and it will not activate the cold start solenoid and fast idle. I think the issues may be related and here is whats going on and why I think that.
Tried to use my blink in the 16 pin diagnostic port today. Only 3 ports are active on this car and was able to pull codes off port 6 and 7 showed clear. However port 3 (CFI) was a different story. Connect my blink to port 3, the light activates at a reduced brightness and when you hit the button the light gets brighter but it will not activate the diagnostic mode and blink a code.
For some reason there is constant voltage on port 3 that should not be there and I strongly suspect the electronic engine controls are all dead. I know several here have experiance with the M103 and KE Jetronic system and I now suspect I may have a bad MAS Control unit in this car. However before I go farther would like some insight from those here who know the M103 KE Jetronic system if I'm on the right track or if there is something else that would cause this issue I'm missing.
