Car Cranks but won't ignite.. Can't read fault codes
jnes
Hi
This is same issue discussed with my previous topic (ignition switch issue) but I decided to make another topic with correct title.
Car cranks but engine won't start. No warning lights at instrument cluster except SRS light. Neither gauges won't work. I tried to read fault codes but I couldn't connect to car. I have Star diagnosis.
Clifford Avant Guard 3 has installed to car in mid -90. What do you think that could this alarm system cause all the problems or are my BM or LH module failed? Car shut down during driving without any warnings. What are the symtoms if these modules fail?
I have check fuses in fuse box and main fuses in BM. Battery is ok.
