Codes through HVAC
When I try and do a search these days I get an "oops" notice. SO- can anyone point me in the right direction to read the codes the HVAC system is putting out?
You need a digital scanner to communicate with the HVAC system in the 140 chassis. Or, it is able to display fault codes directly on the LCD displays.
Click here, see page 21.
:matrix:
There are some fault codes on the screen for things like thermostat, inside and outside temp readings. I read code 14 with the blinky too. I attached the video but can decipher it here in a bit.
14 is Lambda on/off.
