That is a Base Module (BM). It's not a computer that controls the fuel injection or ignition. No coding needed.
Essentially, it replaces the "OVP" (over-voltage protection) relay of earlier/other (KE injection and HFM injection) models, and incorporates some other functions, including:
- Fuse that controls voltage for the stop lamp switch and ABS/ASR control computer
- Fuse that controls voltage supply for the CHECK ENGINE light, as well as the EZL and fuel injectors
- Fuse that controls voltage supply to air injection relay, fuel pump relay, upshift delay, EGR switchover valve, and cam timing solenoid
It is not universal, but any BM for any V-8 W124 400E/500E/E500/E420 will work. They are cheap to buy either here or on eBay. Just search the FOR SALE ads for a Base Module. They can come with either three or four fuses. If you REALLY need one, I have a few and would be willing to let one go.
