Hello All,
Found a good set of wheels locally (17x7.5 ET40) that I am having tires (225/45r17) mounted on later on today...
Test fit the wheels and the front is maybe 3-5mm away from strut, with tires I thought it may be cutting it close. The car is also lowered on H&R springs.
If I run a spacer in the front do I need the cap style to clear the front hub grease cap? I ask this because I needed them for my W203 in the front which has a very similar grease cap hub...
Most I would run is 5-10mm.
Here is the cap style spacer I am referring to:
traditional spacer with lip:
Thx,
ANDERZÉN
Thx,
ANDERZÉN
