Greetings
After almost 6 years of enjoying my second Europa G, I have decided the time has come to sell my beloved G.
I feel this truck is in great cosmetic and mechanical condition and a lot of effort has been made to keep up with service and address any issues that came up over the years.
Services preformed in my ownership.
1/19 - Oil, brake flush, trans oil, dif oil, transfer case oil, lube axles, shifter bushing,
10/19 - low ac check / K40 repair
11/21 - F/R brake disc/pad, engine/trans mounts, fuel filter, TCase mounts, power steering flush, oil change, brake fluid/ brake hoses, conductor plate transmission service.
6/22 - RennTech Tune, plugs wires MAF, tie rods, alignment, accelerator pedal sensor.
12/22 - oil change, mount g55 skid plate bar, spare flip kit, new washer nozzle. 19” spare, matching tire.
2/23 - AC Condenser replacement/ new drier/ AC service. Finally found the small leak that had been requiring annual recharge.
8/23 - Oil change, replace oil pan gasket, trans service.
1/24 - new power steering pump and reseal of steering gearbox, new MB shifter, new central locking control unit, install 4 new under door lights with harnesses, repair of diff locks - vacuum leaks, locker pressure intensifiers, new F/R locker solenoids, front and rear locker hoses, sunroof service and parts replacement, new rear springs, L & R valve covers resealed, oil filter housing leak fixed. Reprogram one key remote, both now working.
5/24 - New transfer case installed, evap code inspection.
6/24 - New MB battery
The car is listed on Bring a Trailer and the link is below. The truck is located in central FL zip code 33823.
Thanks for checking it out and thanks to all who have contributed to questions I have had. Some DIY’s posted here proved incredibly helpful!
Hopefully I didn’t post this in the wrong area, but misc topic G area seemed like the correct area.
-Antonio
-Antonio
