FOR SALE FS: Digital scanner (code reader) for E500E & other Mercedes
gsxr
This digital scanner will work on all Mercedes through model year 2002. It will connect via the 8-pin, 16-pin, or 38-pin diagnostic ports.
I have only used it on my W124 V8's (500E, E500, 400E, E420) with LH injection, so I can't comment on what it does with other models or injection systems. But with LH cars (including W140 and R129), it will communicate with all systems to read & clear codes. It supports digital communication with all modules capable of it (this is much faster than blink codes). You get live data (aka "actual values" or "data stream") from the LH, E-GAS, BM, and DM modules. For DI (EZL) and ABS/ASR, it will only read/clear codes (no live data). The live data from LH and E-GAS is extremely helpful for diagnosing engine problems, and since the E-GAS has multiple codes for each analog code (click here - note there are six different digital codes which all appear as blink code "2"). The digital codes from E-GAS are much more useful than via a blink-code reader.
The kit includes a breakout box for the 38-pin port, so you can more easily use a handheld blink code reader when necessary for certain things... you'll still need the blinker box to check analog SRS codes on a W124, or to re-set the LH module adaptation back to mean values. Pretty much everything else can be done via the scanner directly. Trying to stick tiny 1mm pins into the 38-pin port and hoping you get the right socket is a PITA, the breakout box makes this a breeze with numbered 4mm sockets. The breakout box alone is ~$200 from MB, btw.
Click here for a full batch of photos of almost all the menus/screens for the 500E.
Baum sells the same kit as a refurb unit on eBay for $595 with free shipping:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0622174843
SOLD
:banana1:
Re: FS: Digital scanner (code reader) for E500E & other Merc
Photos of the data screens from the LH module are below.
Hi Dave,
Does it come with an instruction manual and code description?
Regards,
Eric
Hello Eric,
Unfortunately, it doesn't have an instruction manual... that was lost in shipping when I bought it, so I never had one. However, it's simple enough to use that a manual really isn't required. With the power wires plugged in, the on-screen menus tell you where to connect the third (data) wire... see photo below.
For a code list, I have a several PDF documents on my website; including a generic "all model" code list. I created a 124.036-specific list directly from the factory WIS with even more information (I also created a similar doc for W140/M119 and W124/M104 combos). Click here for the 124.036 list, click here for the generic list, and click here for the directory where they are all stored. The generic "all model" list (through '98) happens to be the CS-1000 instruction manual, which is similar in operation to the CS-2000.
The CS-2000 will display the code number as well as the explanation (see photo below), however it would be good to double-check with the factory WIS docs to verify that.
:beerchug:
Sold. Thanks for your interest!
:3gears:
