FOR SALE FS: MB tools
omegabenz
MB Tools for sale, all handy if you own a benz.
Koken 5mm special tool
aftermarket dash removal kit
tool for shifter bushings
SLR impact socket
17mm impact (generic)
wheel alignment tool (12mm)
full set Hazet flex drivers for hose clamps.
hand made univeral for rear subframe bolts
front MB tool, with adapter for front struts (22mm/7mm hex)
7mm hex wrench from hazet with handle
brake caliper brush
1/2 drive, push thru ratchet, with 2 extensions
M104 oil filter wrench
ebrake spring tool, t-handle
The other misc items in the photo, except below
Hazet brake line wrenches (bent ones- access bleeder without removing wheels)
MB dash removal kit
L shaped wrench for rear subframe bolts
M104/m119 fan clutch holder, white snapon handle
Stubby 8mm hex driver for OM60x fan clutch bolt
steering box lock out tool
Klann differntial/transmission flange holder tool (black with two pins) (not pictured)
Ok, most of them have been sold.
I have these left:
Hazet brake line wrenches $100/set
MB dash removal kit (pair of pulling hooks) $20
L-shaped 12-pt/XZN wrench for rear subframe bolts $25
M104/M119 fan clutch holder, white Snap-On handle (custom made by me) $20 + 1/(my ingenuity)
Stubby 8mm hex driver for OM60x fan clutch bolt (works on other fan clutches too) $15
Klann transmission/differential flange tool $50 (kinda heavy)
I can bundle this up, and ship worldwide if necessary.
Shipping will be $5 for small things (for small USPS box), and $12 for medium flat rate box.
Thanks!
