G’day from sunny Australia!
I recently picked up a 1994 SWB G Wagon (Japan delivered) with a M104 engine.
During my short ownership I’ve rebuilt the top end ( with guidance from Gerry’s post, an absolute legend) including head gasket, water pump and related seals and sensors.
However I’m still having an issue with the revs dropping and in some cases stalling with slight throttle input. If im heavy on the throttle there’s no issue but under gentle input the revs drops and the engine stalls or nearly stalls then revs surge back up. There is also a strong fuel smell from the exhaust which leads me to believe it is running rich.
So far to try and solve this problem I’ve also replaced the 02 sensor, crankshaft and camshaft position sensors, plugs, coils, fuel filter, thermostat and a smoke test to find and fix any vaccum leaks and I’ve even opened the throttle body to check for signs of broken wires (visually all looks okay even tho it’s a 94 year throttle body).
This issue is driving me mad and I can’t think of that else may be causing the issue. I’ve hooked up a test light which is showing codes 24,35 and 13 on pin 8.
Any thoughts as to what the issue maybe? Wiring harness has not been replaced by the seems but doesn’t seem to be in horrible shape. I know this is going to have to be replaced at some point but it is a lot of coin and I’m hoping this issue is something else.
