W463 G320 Error log HELP!
Roscoes_Wetsuit
Hi all,
Having rough running/idling issues with my 94 g320 with a m104.996.
I have recently replaced wiring harness when solved some issues but a few still persist. Using HFM scan tool I have pulled the error codes below. Can anybody tell me where purge valve is located on a g320? Any idea what may be causing crankshaft sensor issue? This was also replaced recently.
Hi all,
Hi all,
The purge valve is the one for the fuel tank as far I can take from the list.
But there is 2 type of codes OB15 and MB
See below to compare the numbers.
The MB fault is fuel purge switch valve
The OB15 is transmission upshift.
