My 93 500E has some kind of short in the cluster, apparently on the left hand side with temp/oil pressure/fuel. I am not a DIY person, but my mechanic tells me that there is a circuit board that is bad that is causing the problems. Apparently the grounding of that circuit board isn't working on it either.
It got sent to Palo Alto Speedometer, and they tried to repair but it didn't work. He said my daughter's 91 300E has a different more mechanical type of setup...
Does anyone know anything about this, and if so how I can fix that problem? At first the fuel gauge was bouncing around, and now that seems to be okay but the outside temp gauge goes on and off sporadically and I think other lights might be affected. Thanks for any help.
