I've been having some issues lately with my turn signals and I'm not sure if it's due to several bad relays or perhaps something in the instrument cluster itself is going bad. The turn signal clicking noise will sometimes get out-of-sequence with the flashing arrow. I replaced the relay in the under-hood relay module box and it seemed to have fixed the problem for about a week, but then the same problem cropped up and, this time, the signals and flashers eventually stopped working altogether.
This second replacement relay I'm on now seems to be starting the same out-of-sequence problem and I'm thinking it won't be long before the turn signals and hazard flashers stop working again.
Any thoughts on what could be causing it? Maybe something in the instrument cluster is bad and causing the relays to fail? Is there an additional relay that causes the clicking noise in the instrument cluster?
Admin edit: See post #23 for solution, root cause was a faulty fuel/oil/temperature gauge in the instrument cluster.
