Lorinser 400E Engine swap 5.0 Idling problems
Hi everyone,
First of all i apologize for being repetitive on this topic but i really need some help understanding .
I have done a 5.0 swap to my W124 400E but i am facing big troubles with the idling. I would be pleased if you can share some advices.
So car wont keep the idling if i don't press the gas pedal, and with just touching the pedal a little bit it will high rev 1100-1200 rpm . I have no codes on HTT Win , the car sounds like it's running very well on higher rpm, but once i release the pedal to try to idle it will start shaking and turns off.
I made some tests for vacuum on hoses but everything looks good (i do have a suspect on header seal joints but i need a biger smoke gnerator to be assured ). Actually the engine has the 4.0 LH module, and the original Throttle body. I tried to install the 5.0 LH module with 4.0 throttle body , clearing all codes with HTT win, but the idle wont improve, engine wont run good on high rpm too.
Looks like with te 5.0 LH the mixture is very reach. Also what i noticed is that with 4.0 LH the throttle will show 2.6 degree open at 1100rpm “forced idle” while with the 5.0 LH module wont read the throttle angle at all. I am attaching a video with the 5.0 LH module instaled . Any opinion would be appreciated.
Thanks in advance
Saimir
Hi everyone,
Thanks in advance
Saimir
