Very funny you mention that! Even if a 928, R129 or .036 is the "better" car imo, the SLK is awesome - especially for the money they go for now and with cheap and easy to find parts!The funny thing about the R170 is, it's a fantastic car. Once I got over the interior, I realized that it's one of the most underrated Mercedes.
I've actually tried to sell it at every opportunity, to pick up something else like a 928 Porsche or R129 but it's such a better car. It's not an E500E
of course.
Dan,Everyone's insight into the SLK is quite helpful - I'm constantly on the prowl for an SLK320 for the wife as replacement for her R129 (97 S500). The interior issues seemed to be somewhat resolved in later model years, thankfully, and the top hydraulics can often be a good negotiating point as by now they're starting to fail, despite being easy to repair.
If I could just find a nice yellow one. They're pretty rare in that color.
Dan
Dan,
the interior problems on the first series (1996-2000) can be fixed in various ways:
You can use some special laquer (need to look up the name), but the results depend on the interior color here. Black can be fixed quite good, other colors not so much.
Or you can coat the middle console... with real leather in matching color. The way MB should have done from factory, but expensive!
The facelift cars tend to rust more, especially the 2000 and early 2001 made cars. And the performance of the 320 is not better than the 230.
Edit: You are in Florida, so forget about the rust topic
They look awesome in yellow imho! I want one since I was a little child and had one as a toy car...
A yellow 320 is super hard to find. They stopped the yellow color a short time after the facelift.
What is wrong with the R129 SL?
Dan,Thanks!
Yes, rust is rarely an issue here in Florida, or for that matter anywhere in the south or southwest part of the country. Same with the W210s - you don't see them in the northern part of the country because they rusted away, yet they are cheap and plentiful here.
Yes, the interior issues are one of the reasons why I focused on later models. I don't want to have to refresh an interior, although I could certainly do it.
I realize the M112 isn't any better than the M111 for a number of reasons, but it's more robust and economical engine, and I already have two in the fleet so it makes maintenance and inventory of spares easier for me.
Nothing wrong with the R129, in fact, it's got to be one of the best Mercedes I've owned over the years. It's gone from 70k miles to nearly 140k miles in 7 years and been amazingly trouble free throughout that time. The real irony is that it's my wife's car, and she drives it in, shall we say, a very "spirited" manner. I believe @gsxr refers to her driving technique as "binary throttle control", if that makes sense. I don't ride with her as it scares the heck out of me. If we go somewhere I drive.
I would just like to get her in a newer car, ideally to gain some economy as she's lucky to hit 15 mpg in the R129, and because newer = safer.
Dan
The SLK 230 is lighter in the nose than the other R170s. It also gets better gas mileage indeed, but that doesn't stop me wanting an SLK32AMG. Drove one once, they are like lightning. I find the SLK to be a perfect city car, but it does remarkably well as a GT. The seats are wider and far more supportive than the W124.
For some reason I find my pre-facelift seats kind of lacking support. If there would not be that airbag-sensor integrated into the passenger seat, my car would already have some Recaros or similar.
Thank you very much for that tip, Dan!There is a bypass module that's sold in the aftermarket for the passenger seat airbag sensor. I bought one for my S210 wagon because I was too lazy to disassemble the seat to remove and replace the sensor. I can dig around for a link - the seller was in Germany.
Dan
That is great to know.
Dan, thank you very much for looking this up again for me! I appreciate thatI think this is the seller:
Passenger Seat Occupancy Mat Bypass MERCEDES BENZ SRS Airbag Sensor Emulator Fix | eBay
They have one device that I believe works with a number of different models depending on how the DIP switches are set on it. It took all of maybe 2-3 minutes to install and set up.
Dan
744Brillantsilber, I finally did a pressure test and all cylinders were great. That led me to the simple problem with the ignition coils that you mentioned. I'm told these engines like to eat spark plugs and it is very likely that I was running on worn out ones for too long, leading to the ignition coil failure. Thank you for the correct advice. I was expecting a larger problem because I have never seen an engine shake like it did. I once drove a 500E 4000KM across the country on only 4 cylinders (bad harness). Other than the lack of power and a CEL there were no other symptoms. M119!@ALL500: Thank you for the picture and the video!
From the video, it looks like it is not running on all cylinders imo.
I doubt it is the valve cover seal.
First, I would recommend you to pull all for spark plugs and see how they look.
I do not know your tools, but doing a pressure loss test (is that the correct translation?) would be easy and helpful!
Since it has no direct injection, the fuel system should be fine.
So it is probably something in the ignition (probably a spark plug, cable or one of the 2 coils) or you get that much water in the cylinder, that the fuel-air mixture can ne be ignited. With you loosing water, it probably is the 2nd option.
That should be visible on a spark plug and can be testet with a pressure loss test.
That’s certainly one way to go CAT-less!I once drove a 500E 4000KM across the country on only 4 cylinders (bad harness). Other than the lack of power and a CEL there were no other symptoms. M119!
