Exactly correct. This has been discussed previously... if you insist on a stick shift, the E500E is not for you.However, I personally believe the 4 speed automatic gearbox in the 500E500 suits it quite well. Yes, its a bit slow and dated, but if you want an engaging and rewarding driving experience, don't buy an old mec [emoji28] they have their own charm and desirable attributes, but a sporty driving feel is not one of them.
That said, the 722.3 auto trans is NOT as bad as most people think. The problem is, most people are driving E500E's which have worn, tired transmissions (or, sloppily rebuilt) that do not perform as the factory intended. A fresh, properly-built 722.3 auto works very, very well. If you've never driven one, you may not believe it. No, it won't be as great as the newfangled electronically-controlled autos, but it's fairly close - IMO.
Maybe a 722.6 is a good alternative. The 5 speed with a 1st gear start should wake the car up and you can mount paddle shifters. It takes the kid that works for me a couple of days start to finish to get one installed.
First gear start and a freshly rebuilt gearbox definitely wakes these us. The only thing I miss over the .6 in my S55 is the ability to downshift and rev match without accelerating. I could, as Klink suggests, "slap my shifter around like a red headed stepchild" and I often do. But then I miss the paddles. I guess I'm lazy, which is why I prefer my MBs over my BMW M. And why I'm completely uninterested in driving with two feet.
Question for the gurus: might the manual from the SL320 R129 cars work, or is the bell housing different? It might be worth a call (as a start) to call Marc at Sun Valley Mercedes, but that might only net you the gearbox. The rest of the infrastructure is on you. Good luck.
The bell housing bolt pattern between an M104 and an M119 are definitely different.First gear start and a freshly rebuilt gearbox definitely wakes these up. The only thing I miss over the .6 in my S55 is the ability to downshift and rev match without accelerating. I could, as Klink suggests, "slap my shifter around like a red headed stepchild" and I often do. But then I miss the paddles. I guess I'm lazy, which is why I prefer my MBs over my BMW M. And why I'm completely uninterested in driving with two feet.
Captruff installed a five speed in his wagon.
Any pics or details on Captruff's conversion ? Does he still like it ?
I have a 5-speed tranny, pedal box, speedo, shifter assembly, diff, and driveshaft(s) from an early W124 300E.
Still need to find a M104 flywheel and clutch, before I mate it up to my C36-powered S124 wagon . . .
Anyone have a source for the flywheel in the USA ?
neil
Thanks Jeff! I assume your tranny came with the flywheel . . .
neil
I'm still running the standard 3.2L M104, but I had a 3.6 being rebuilt for an eventual swap. Additionally, I put in a 8K read tachometer from an early M104 with a 7k redline and although this is not accurate for the moment after I swap the 3.6 and have some additional work done the 7K redline will be a reality.
Jeff- what sort of modifications are you doing to the 3.6? I am hoping to get the manual trans and 3.27 lsd diff into my C36 at some point this year.
How will you go about doing that with the HFM injection on the 3.6? The HFM ecu's are like a black hole for tuning.
I almost bought an E23 745i with the M102 K27 instead of the 500E,
Hi, if done it some years ago, look at my nickname and you will find it.(Too) soon after acquiring my '92 M104 300CE (with it's ideal 3.06 rear) I began collecting the parts necessary to convert to 5spd...I ended up finding a 190E 2.6 5spd parts car complete, with a 2nd identical gearbox/flywheel/clutch/pedals/hydraulics/etc in the trunk.
All together an easier swap with a CIS-E car I believe, at least as far as finding the correct flywheel.
However, given that the auto box in the coupe performed flawlessly (while I Sportlined the suspension), by the end of that 1st year it took to pull all that stuff together and get ready to install, I decided that I was quite happy with the autobox setup as delivered.
I ended up selling all the relevent stuff to David H. who easily dispersed it around the world...
Still happy 3 years later.
And, for no good reason I have a similar complete 5spd setup (717.410), tho' from a mid-80s 190D, suitable for most any similar vintage 201/124 diesel...Open to a reasonable offer.
Hello Guest !
