- UPDATED -
Ok, today I solved a lot of things, and this must be the greatest day with my 500E so far!
Below I'm suggesting the symptoms and the remedy, but since both parts were replaced together it's difficult to say for sure.
I replaced 2 parts:
A: Fuel pressure regulator
B: Neutral safety switch
- Fuel Pressure Regulator -
1. hard engine starting - especially after sitting for 3-4 days - (a lot better)
3. unsteady idle (better)
4. erratic idle (better)
8. noisy fuel pumps (fixed)
10. bad fuel milage - about 1.25-1.35 l/10 km (17 MPG - 19 MPG US) - very gentle driving on highway - should be 23-25 MPG** (slightly better)
13. hesitation/lock at WOT 4000 rpms right after kick down (fixed)
14. real long shifting at WOT 5500 rpms (better)
- Neutral Safety Switch -
11. very low idle (450 rpms) (fixed)
12. frequent ASR issues (not the issue - ETA must be replaced)
- Not fixed -
2. frequent lack of cold start function, which should run engine at 1100 rpms for 20 second (unconfirmed)
5. push and pull while driving normal / felt like some kind of incorrect compensation (unconfirmed)
6. engine misfire (not fixed)
7. loss of power (unconfirmed)
9. bad spark plug at cylinder 8 - totally black while the others were clean (unconfirmed)
I suspected the fuel pressure regulator after reading this:
http://www.buzzle.com/articles/symptoms-of-a-bad-fuel-pressure-regulator.html - which pretty much resembled most of my symptoms.
And thanks to this forum for the many excellent writeups and info about the NSS on this forum!
I believe a bad fuel pressure regulator can cause a LOT of weird drivability issues, and I really recommend replacing it. Price is $65 or so, DIY 30 minute job. Check Gerry's writeups and recommendations! Thanks Gerry for those.
Please correct me, if you are convinced any of the above is ludacris
