When it rains it pours. While E420 #1 is down with lower harness repairs #2 just started dishing out battery/possible alternator issues. Part of the problem is that #2 is primarily my girlfriends daily driver, let's just say she may not be as perceptive as I am when quirks develop.
As we left to an appointment late this morning the starter cranked very slowly, I figured if the battery was on it's way out a nice ride on the freeway would get the voltage up at least temporarily. I dropped off the girlfriend and left to run errands, this time the starter seemed to crank even slower. My next stop was the closest auto parts store where they could do a quick test.
Seems I need a new battery (sure), which is pretty much what anyone testing a partially charged group 49 will tell you. I had the guy check the alternator output which was just over 11 volts; seems like a charging issue to me.
One puzzler though, if I'm getting low alternator output shouldn't that trigger the light on the dash? No dash lights. I left the parts store with their cheapest battery to have as a back-up; this gave me enough confidence to continue on running errands for the next hour and a half. Three separate start and restart cycles w/o incident; if there is a charging problem it seems like it may be intermittent.
Picked up the girlfriend, drove from LA to Pasadena running the a/c, made two more stops before heading home and didn't get stranded. Now that I'm home where should I start?
