So the time has come to get an alignment done and I have means to have it done at the shop that got me the HRE wheels and the new Conti’s Extreme Contact (DW) tires - Goodyear stopped carrying the 245/45/17 sizes so I went with Conti’s and for a good chunk less in price. The shop is mostly for Porsche clients, but do have a few Benz clients and the owner has a 1995 SL500 as his daily driver.
For the alignment, the shop has a Hunter machine and after looking for right operator for two years, they found a guy who is very good and has done all types of exotics over the past 25 years. The questions I have are:
1. With wider wheels/tires and front offset at 27, should I bring the factory specs just in case, or will the machine use the car model (W124 E class) to get the right specs? Or should the R129 specs be used from the machines model’s index?
2. With the laser system from Hunter, do I still need to pursue a spreader bar for force simulation, or can I just ask to use some kind of weights in the front floor, and what is the weight/pressure to be applied?
Danke.
Danke.
