Hello there,
I have a big problem on an E420 '93 , its without SLS.
On the bottom of the power steering pump is a massive oil leak.
I already resealed the power steering pump with the original MB parts and also sealed the reservoir and Renew the Hose between reservoir and pump.
On the top is all dry and I cant see any leaks.
But the bottom of the Pump is full of oil.
I think its engine oil because there is no steering fluid missing.(its on MAX, still after 50 kilometers).
Is there maybe any bolt which goes inside the engine and leaks engine oil to the bottomside of the steering pump?
Thank you very much - I dont know what to do now.
Already cleaned Up and ride some kilometers/Miles and checked after ride but see no leaks
The leak is very heavy but cant see where it comes from?!
