Hello,
A while back I was searching for a lower wiring harness for my 1993 400E. My oil pressure needle was pinned to maximum oil pressure and would sporadically twitch nervously.
The lower wiring harness for my car is NLA, and after being unable to located the part new/used anywhere I had a mercedes/bmw shop with good reviews on Yelp take it out, rebuild it, and put it back in.
However, my oil pressure needle is still pins to level 3 as soon as the car started and remains there until I've been driving for a while, after which she starts twitching sporadically. My assumption is that since the lower wiring harness has been rebuilt, it must be the sensor itself. I also assume that the needle gets twitchy only after driving for a while because the engine compartment gets really warm, and electrical properties of the oil pressure sending unit change.
I also think that the twitchy needle shows correct pressure, as sometimes it'll stay - while twitching- for 2-3 seconds at 1.2 bar, which is the idle oil pressure I remember on 5w-50 after an hour or so of driving
Please let me know your thoughts on whether you think: the oil pressure sender or perhaps the lower wiring harness is culprit because it was not fixed properly?
Here is behavior of my oil pressure needle after 40+ minutes of driving:
https://www.youtube.com/watch?v=WwvZkPkzlqU&feature=youtu.be
