Ahh....yes, that certainly could be something.
I was just topping off the air in the tires a few minutes ago for the trip (pressure was at the 34.5-36 psi level, even after the winter, so the tires are holding air nicely), and did some more investigative work in the engine bay. It appears that the area under the passenger side front of the engine, under the lower radiator hose, is wet on the lower under-engine panel. Can't tell right now if it is grease, or coolant. Running my hand on the ground side/edge of the cladding was inconclusive, but it seems that it could indeed be coolant.
Took the front top engine panel off, and no apparent leaks at the intake manifold, at least from the front. Zero leaks from the heater hoses - those were easy to see in the back of the engine.
A couple of things did give me pause though - a spray pattern on the driver's side ignition cap cover - as shown on the photo below. This is right behind the upper radiator hose connection at the radiator. Nothing wet, and the spray pattern didn't appear wet.
You can see from the other close-up photos of the lower radiator hose on the passenger side, some of the wetness/drops I was talking about on that hose. It is seeming that this could be the problem, though. I don't know why the drops on the hose itself are appearing very green (like green coolant) as I have ALWAYS used the proper straw-colored Zerex coolant in the system.
No leaks from the expansion tank hose connections, for sure. It seems very centered on that lower passenger side area of the front of the engine.
When I get back I'll have to take off the lower cladding, pressure test the system, and really look under there, and see if anything drops onto the ground (will put a pan there to catch anything). That will tell me what any fluids are.
I'll pop the hood when I get to the Dulles Airport parking garage to see if I lost any coolant on the trip there.
Investigative photos below.
Driver's side ignition cover:
Views of vertical and joint areas of lower radiator hose. Dunno why things appear green there, as I have never used green coolant.
