WANTED Receiver / Dryer for 92 400e
JDAMG
Mine is leaking, went through every aftermarket unit under the sun and none of them have the connections in the proper locations. Does anyone have a NOS or even just one that doesnt leak? Thanks!
Mine is leaking...
Where is it leaking from? I've never heard of this before!
...went through every aftermarket unit under the sun and none of them have the connections in the proper locations. Does anyone have a NOS or even just one that doesnt leak? Thanks!
It may be possible to bend the hard lines slightly, and modify the mounting brackets, to make a 6-cyl unit fit the V8 connections. This was discussed previously (link).
I haven't seen a NOS one for sale since before they went NLA, if you find any, I'd like to buy a couple! Used should be easy to locate but you may need to use creative methods to ensure the dessicant inside is dry - maybe heating in an oven at low temp? Then a loooong period of pulling deep vacuum prior to recharge. Or you can try what looks like a proper-fitting, no-name aftermarket V8 unit from a seller in Germany - see post #33 in the thread above.
