@WDB748372 - that is a great question. I started using a RaceTechnology AP-22 meter nearly 20 years ago, at the time it was a pretty good solution, although it had no GPS capability. Around 2011, I upgraded to the AX-22 meter for ~$350. The AX-22 has an external GPS antenna, and also an input to log engine RPM from the tach (cool stuff, if you need that, may not work on a 210 though). I found the AX-22 was within about 1-2% of dragstrip timing lights which was adequate for my needs.
This was going to be a follow up question. I was sold on the Dragy unit due to it's accuracy and easy to use interface but couldn't tell if it was capable of measuring between any two speeds. That was a huge drawback. There looks to be some default metrics only.Make sure the meter is capable of measuring between any 2 selected speeds
I'm sure you're aware of this, but I figured I'd call it out explicitly. The Mini-S does not have a screen, and does require linking to a phone or tablet to configure, and to read back recorded telemetry, but a phone or tablet is not required to capture and record data. It can record as a standalone device, and then you can pair with your mobile device after you're done racing to review your results. Might not make much of a difference to most, but for some who are worried about needing to bring their mobile device on track, it's worth clarifying.I'm on the fence about a unit that requires a phone/tablet to function though, which is the difference between the Mini and larger/standalone Racebox.
Yes - good clarification! I also need to verify that the recorded data is easily accessible on a Windows PC. I don't process data on a portable device. It's likely saved in a CSV format which can be opened in Excel, similar to the AX-22.I'm sure you're aware of this, but I figured I'd call it out explicitly. The Mini-S does not have a screen, and does require linking to a phone or tablet to configure, and to read back recorded telemetry, but a phone or tablet is not required to capture and record data. It can record as a standalone device, and then you can pair with your mobile device after you're done racing to review your results. Might not make much of a difference to most, but for some who are worried about needing to bring their mobile device on track, it's worth clarifying.
"Easily" will depend on your tolerance for jumping through hoops.Yes - good clarification! I also need to verify that the recorded data is easily accessible on a Windows PC. I don't process data on a portable device. It's likely saved in a CSV format which can be opened in Excel, similar to the AX-22.
Awesome - thanks for confirming! Could you share a sample CSV, if available?"Easily" will depend on your tolerance for jumping through hoops.
When you record a session, you can save the session from your mobile device, at which point it will upload to your cloud account. You can then access your cloud account by logging in to your account on the Racebox website. From there, you can download your session data in a number of different formats, including csv.
I just tested it and was able to download the csv and open it on my pc just fine.
Appreciate your input. Didn't know but that is also huge plus too. So far this looks great and worth the difference compared to the Dragy. I'll do some more digging on this unit. Thank you again.it does not need to be constantly paired to my phone to capture data is a big plus.
That's honestly how I came across it. A YouTuber was using it in parallel during his 1/4 run and I was impressed how accurate it was given the price point.I get the impression this is more of a social media tool intended to upload directly from the required-phone to Bookface/Instatweet/Tickytok/Gram.
That's great to know as well. Again a more applicable case where I would want to use it and not have to hit 130mph every single time to get some sort of metric like the Dragy.Racebox does allow selecting any 2 speeds and supports "rolling start" as well - not sure if Dragy supports that.
Correct - any good unit that receives high-resolution GPS signals (i.e., 10Hz or better), should be able to provide very accurate data. The difference then becomes the UX/UI, and features available from the hardware and/or software, i.e. rolling start capability, selectable start/end points, battery life, external antenna capability, etc.That's honestly how I came across it. A YouTuber was using it in parallel during his 1/4 run and I was impressed how accurate it was given the price point.
Exactly. We want more of a true datalogging solution, that also shows some commonly desired metrics like 0-60, 0-100, 1/4 mile, etc. The AX-22 software is not user friendly but it has all data in 100Hz (0.01-second) increments.That's great to know as well. Again a more applicable case where I would want to use it and not have to hit 130mph every single time to get some sort of metric like the Dragy.
First thing came to mind for me was 0-60. That's a great point though, it would be more accurate for me to do a rolling start. Will keep weight in mind too.As a side note: When measuring performance, I've found that low-speed measurements such as 0-60 are not particularly useful. There is far too much variability at the launch, based on traction on public roads with street tire compounds. Wheelspin can cause times to be several tenths of a second slower, and can be as much as 1-2 seconds with severe spin and ASR/ESP intervention.
