replace the knock sensors on the engine block.
Berglund
Hi. I have decided to replace the knock sensors on the engine block. They appear to be located next to / inside the engine mount.
Is it possible to replace these without removing the engine mounts?
The wiring to the sensors has become a bit dry and cracked
Does anyone on this forum have experience with having this procedure done?
Have a nice evening
// Niklas
Not possible to replace without removing the engine mounts, AND the engine mount bracket (bolted to the engine).
If the sensors are still working (no fault codes on the EZL)... I would leave them alone. The knock sensors are NLA. They are a rare failure.
:wormhole:
