I'm trouble shooting a low speed drive ability issue on my 92 500E w 245k mi. The issue manifests itself mostly at low speed and idle in D, but also in P/R/N, with the car struggling to stay above 500RPM when stationary and then lurching a bit at low speed and sounding quite rough. Once or twice it's even just shut itself off at low speed. This has also periodically been an issue on the freeway: it doesn't pull very strongly/does so unevenly, and it frequently feels dead until above 3kRPM. It also sometimes refuses to kick down.
To date, here's what I've done
- Caps and rotors are new in the last year or two. Bosch caps, Dudoco rotors, new insulators, new oil seals. Typically dry in there.
 - Plugs at 1mm gap
 - New NSS
 - CPK is about 10 yrs/35k mi old and is good brand.
 - Confirmed that the cats are clogged and need replacing. This explains some of the freeway behaviour but I don't think it would explain the low speed issues.
 - Codes checked today after clearing a while ago
- LH, ABS, ACC, STS are all Code 1 only
 - Pin 7 EA/CC/ISC is code 6
 - Pin 8 Base Module is code 12
 - Pin 17 EZL is code 8
 - Pin 19 Diagnostic Module is code 12
 - New battery for general posterity
 smokers.  If you've shopped install quality, I'd go with your preferred installer and the Magnaflow cats.  Unless you're selling some restored museum piece, the car running well will be worth much more than which exhaust you're running.  You don't want them ugly, but they're actually not in a beauty contest.
