I'm recieving following fault when trying to read fault codes from the car with Star Diagnose:
Internal fault
Diagnosis Multiplexer
Code: 10766
Does anybody have clue is the problem with the car or with SDS C3 multiplexer? Previously SDS has connected and worked normally when reading fault codes.
Main reason for reading fault codes is that car won't fire up. I've tried to read fault codes with blink tester before SDS but blink tester did not work at all. I may have connected wires to wrong pins (wrong order). All warning lights come on when turning the ignition on.
Is it possible to have short circuit some computers with blink code tester when connecting wires in wrong order? There is no fuse in my blink code tester.
Regards,
joonas
Internal fault
Code: 10766
Regards,
joonas
