Spark plug wires.
Trae
Hi guys,
I had been chasing a misfire on my 93' 500E for a month. I had replaced spark plugs, caps, rotors, and insulators behind the rotors thinking it might have been a moisture build up behind the cap. Car ran fine cold, BUT would misfire as soon as it reached operating temperature.
Then, I started focusing on the suppressors that fit over the spark plugs and the terminals that fit over the cap. Measured each wire for 2,000 ohms of resistance +-10%. Number 8 wire tested a little out of range, so I replaced the terminal and suppressor. Still, I had a misfire after warm up. The wires were a mix of Bremi terminals and Karlyn suppressors. I was not impressed with any of them.
Finally replaced all 8 plug and both coil wires with new Beru wires made in France. Dave sent me this link and I am very happy to report that my problem is solved. Select the wires that are specifically for YOUR YEAR MODEL because they are cut to the proper lengths based on year model. 1992-1993 500E, OR 1994 E500.
If you decide to do this job, Wurth Rubber Care will be your savior and make life very easy when adjusting wires and connecting them to plugs and caps.
Many thanks to Dave for his excellent pictures and link to these wires.
Also, many thanks to Jono as he told me about Rubber Care and wire numbers to the corresponding cylinders that are listed in the plastic tracks. It would be difficult to do this job without those numbers.
This was my first time to replace wires and it took me 4 hours to make mine look like Dave's pictures, but I think I could do the job in about 2 hrs. now. I ordered wire markers and clipped them onto the wires BEFORE I started the job by measuring each wire first and labeling them. Made it easier to keep up with the wires.
Link to PG Beru wires:
W0133-1599712 | Partsgeek.com
Wurth Rubber Care:
After a few thousand miles, these wire markers will expand due to heat and slip around on the wires a bit, but none have come OFF the wires.
Shrink wrap markers should be used to alleviate the slipping problem.
Wire markers:
This photo shows the correct wire routing:
http://www.w124performance.com/images/M119/EZL/wires/M119_ignition_wires5.jpg
More pictures here:
Index of /images/M119/EZL/wires
I'm also in the process of trying to eliminate rough running problems. I'm at the point where I want to reroute my ignition wiring. I have two questions;
The wiring done by a previous owner/technician/amateur has two problems that are apparent. First, lengths are too long, and secondly, they have not used the channels designed for routing. Routing is like a plate of spaghetti.
Question 1, is it possible to cut and re crimp the existing wires? This provides two benefits, first, rerouting is easier since there is virtually no clearance to pull the female sockets through the tight openings, particularly a bracket that holds the fuel filter. Second benefit is that getting rid of excess length results in a neater result.
Question 2, as an alternative, has anyone removed the fuel filter power steering reservoir bracket that can advise me on issues that arise from doing this? I've attached the pic of the filter and bracket.
Thanks for any and all input.
That looks like they stood back 10 feet and threw those cables at the engine!
I would expect that once properly routed those cables should be OK length wise. Any extra length in cable can be tucked away under the plastic cam cover trims.
Yes, that might be an accurate description!
Logic tells me though, that with more efficient routing, I'll have greater excess length, not necessarily an OK situation. You're right, of course, I could tuck the excess under the cover, but that would keep me awake nights. 🤔
I agree. I'd just get a set of the Beru wires, which for $200 are of great quality and cut to the perfect lengths. Install and be done with it.
Thanks all of you for your input. I think I will get a new set of Beru wires. It had been my plan to test the resistance of each wire as I routed it, and in doing so I discovered difficulty in establishing continuity, let alone appropriate resistance.I continued for the point of seeing if I could do a better job of routing the wires, and did that. Once I cleared the jumble of wiring under the power steering reservoir bracket, I had enough room to work the insulators through. (And a thank you to all of you who graciously didn't correct my misidentification of the power steering reservoir. My mind was on a different planet.)
After rerouting the ignition wires, the idle is still rough, as I expected. The new set may solve the issue.
Using my new code reader, I identified 4 codes connected to the MAF sensor. As a quick test, I disconnected the MAF connector to see if the idle would smooth out; it did not. My gut tells me that doesn't necessarily rule out a problem with the MAF sensor.
So, the search continues.
I just received my Beru wire set from Partsgeek. Looks quality but I have not done the install yet. Box is really large, by the way! When it was delivered I thought it was something else.
