Hi, I've been chasing a problem for a few months now which I thought I had solved for a while there but it's back now with vengeance and driving me nuts.
The symptoms only present themselves once the engine is fully warmed and at highway speeds, usually after 5-10 minutes of running at speeds of 125-140 km/h. The car will be happily cruising along at light constant throttle, until almost on cue, the engine will stumble and surge. The slightest adjustment of foot pressure on the pedal however will smooth it out again, and there seems to be plenty of power available even once the problem starts - only at light throttle it happens and will repeat itself until the car is parked up again to let cool, the idle however is not effected at all and I can drive normally once off of the highway as if nothing is wrong. The strange thing is, if I keep the speed below, say 120 km/h (3000 rpm ish) initially, I can drive around all day and it will not manifest itself at all.
The weather here at the moment is hot, like 40C + every day, but the cooling system in in good shape so I don't think heat is the issue, especially since it does not give trouble even when idling in traffic - only out on the highway, the temp gauge never shows any cause for concern.
I built myself a blink code reader and have been slowly working through the codes, to the point where there are no recurring codes any more apart from the temp exceeded in CAN box one (yes the blower works). The code reader, in conjunction with the meticulous records that the PO kept, have enabled me to catch up with bits and pieces that were due for replacement anyway.
So here's what has been replaced in the past 6 months -
fuel pumps / filter / relay / regulator / engine bay fuel lines
plugs / leads / coils / caps / rotors
vacuum lines
O2 / MAS / air sensors etc
EZL / cps (both) / cam sensor
radiator / hoses / thermostat / cap
stop light switch / gear select switch
The ETA and wiring looms (upper and lower) were replaced in 2006, and looms are still good under the sheathing.
The car has around 190,000km on it now.
My head is telling me ETA, but surely a new unit would last more than 5 years??
I suspect what I need to do is get somebody who can read the live data whilst the problem is showing itself, anybody else care to suggest something I've missed?
vacuum lines
