Hi all, I'm starting a new thread as a follow-up to one that died out back in November (E420 fails smog miserably). Still haven't passed smog but I've been busy with the holidays, etc and just got back to working on the car. In the interim I replaced a badly needed flex joint and a throttle cable; shortly afterwards I started seeing some odd behavior that could be related to my smog problem.
On start up the car is now exhibiting an unstable idle that eventually levels out around 750 rpm, the previously working cruise control is now inoperative. Turning on the a/c brings the idle speed down to 500 rpm. Pulled codes today and I got 2 from pin 7 and 6 from pin 19. I had a hard time clearing the 2 from pin 7 so I tried clearing and re-checking w/o cycling the ignition and that seemed to work, that is until I re-checked after the ignition was cycled; it would appear code 2 is resetting immediately after the ignition is switched on.
Per the bit of research I've done this looks like it could be an ETA issue. The upper harness is a replacement Delphi part and looks to be fine, I don't want to touch the ETA harness because I'm sure it's original to the car ('94, non-ASR). Does it sound like I'm close?
