Another easy way to tell which type of fluid is leaking is to monitor the levels of the SLS reservoir, and the power steering reservoir.
From my experiences some years back and just over the past week, a power steering fluid leak from the short hose/reservoir (a gravity leak) will leak continually, even when not driving the car. In a seal type of leak, the liquid will get forced out of the seal when the shaft inside the seal is moving, and won't leak/seep nearly as much when the engine is not operating.
I would say that 80% of the time, a power steering leak is going to be at the "short" hose under the reservoir. The short hose leaking will result in fluid running down the side and below the pump, and you can see drips on the bottom of the tandem pump adjacent to the mounting plate that it is bolted to.
You can see all of the other connections of the power steering system, such as the screw-in metal "U" hose connection on the side of the pump, the return connection on the back of the PS fluid reservoir, and the "S" hose that is below and behind the tandem pump. If these are leaking, you will see fresh fluid on them.
Best if you can spray concentrated streams of brake cleaner all over and around the tandem pump and its connections, including in the short hose area, to clean away any accumulated dirt and such, and to provide a fresh clean surface to visually review any leaks or seepage.
